Features: Designed to cast a soft ambient light over a wide area Clear Metal Rectangle Shade Lamping Technology: LED - Light Emitting Diode: Highly efficient integrated diodes produce little heat and have an extremely long lifespan. Specifications: Height: 14" Width: 7" (measured from furthest point left to furthest point right on fixture) Extension: 2" (measured from mounting surface to furthest protruding point on fixture) Backplate Height: 13.88" Backplate Width: 6.88" Product Weight: 3.31 lbs Bulb Base: Integrated LED Bulb Type: LED Wattage: 10 Bulb Included: Yes Compliance: ETL Listed - Indicates whether a product meets standards and compliance guidelines set by Nationally Recognized Testing Laboratory (NRTL) . This listing determines what types of rooms or environments a product can be used in safely. Since 1954, George Kovacs has been at the forefront of developing the modern and contemporary design concept. These bold ideas have been conceived, then incorporated, into visionary lighting designs. They have become the favorites of today and the bold trendsetting styles of the future. Kovacs lighting fixtures cover the array of indoor lighting including: chandeliers, pendants, wall sconces, lamps, track and under cabinet lighting. Experience for yourself the visionary legacy of George Kovacs in the choice of ceiling lighting fixtures in your own home.
Store | Price |
Build.com | [show price] |
These wall lamps & sconces are well made, quite comfortable, washes well - doesn't fade, would recommend Kovacs P1228-564-L LED Outdoor Flush Mount ADA Wall Sconce from the to all!
